Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Size trailer to haul freewheeler
Old 11-09-2016, 11:58 AM
Rickm's Avatar
Rickm
Rickm is offline
Default Size trailer to haul freewheeler
I'm thinking of getting a freewheeler but it's in the next state so I need to know how big of a trailer I need ? Can't ride it home as it's to cold, Will a uhaul 5X9 open work ? Thanks Rick
Old 11-09-2016, 12:08 PM
graygoat's Avatar
graygoat
graygoat is offline
How wide is the actual tailgate opening, that will be the key on if the Free will go through it and not damage the fenders. Some Free owners here will give you a better idea. Good luck.
Old 11-09-2016, 12:23 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,250 Likes on 11,136 Posts
I have a 6x12 enclosed. And my TriGlide fits comfortably. But as mentioned, make sure the ramp is wide enough. By the way, the measurements don't necessarily reflect the exact interior dimensions.
But, here's a novel idea. Go to a Uhaul dealer and measure it.
Old 11-09-2016, 09:45 PM
Bowler Jerry's Avatar
Bowler Jerry
Bowler Jerry is offline
Have a 6 x 10 enclosed trailer and Freewheeler fits in but only have 4" clearance on each side going through door. ,7 ft would give you more clearance on each side.
Old 11-10-2016, 08:12 AM
rhino 2's Avatar
rhino 2
rhino 2 is offline
5 Foot wide won't do it... You''ll need 6 feet......
Old 11-10-2016, 06:07 PM
graygoat's Avatar
graygoat
graygoat is offline
With my Tri and my 6x10 v, there is only about 2" of clearance on each side and that is between the ramp door cables (narrowest point). I screwed wood guides to the ramp & floor to keep my wheels where they need to be to clear.
Old 11-10-2016, 06:12 PM
Casper's Avatar
Casper
Casper is offline
I had a 6X10 and as others said it fit but was close. I traded for a 7X12 dual axle and it's great.
You don't say where you're located, someone may have a trailer and for little money or maybe even a good meal would help,you out.
JimTJr
03-16-2020 05:33 PM
bagger51
16
02-24-2017 10:59 PM
F.T.P
07-31-2010 05:30 PM
hoosierbagman
12-08-2009 12:29 PM
jackinthebox
09-29-2009 12:59 AM
Quick Reply: Size trailer to haul freewheeler
