30+ PSI rear shocks?
I am aware that everyone adjust this to their preference, but I'm seeing most are at 30+ psi on the rear shocks, I tried 20 and my wife has a horrible ride, 15 seems to be optimal for her, shes about 120lbs, I'm 260 and It makes no difference to me what the psi In the rear Is, It doesn't change my ride at all.
My setup Is 23 psi both rear tires and 15 at the shocks, rides beautiful.
When we picked our 16 TG we took it down the road about 10 miles for a bite to eat. We got off and looked at each other thinking we had made one big mistake. What a rough riding SOB! After we got home I checked the shock pressure and found it at 25 psi. I'm 235 and my wife is around 135. On our 12 Ultra we ran about 45-50 so up she went on the TG. That made all the difference.
I haven't found that sweet spot yet.... 40 thousand miles+' And to be honest i don't think there is one...Just when i think i found it... I ride over a few bumps and realize i haven't found the magic number yet.. Too much psi and a hard bump will jar you .... Too little psi and the shocks will bottom out...There isn't any middle ground....
Mine had a habit much like you describe with yours. But to have a shock that works like a real shock & not an air spring will make a world of difference.
The reason I went with the air is I change loads a lot & didn't want have to get under the trike or take off a wheel just to adjust the shock weight capacity.
