Reverse dying
Received 3,940 Likes
Reverse dying
On my 14, at a little over 40k miles now, the reverse is starting to go out.
It was around the same mileage on my '11 when the reverse failed.
Gonna have to take it in for warranty replacement.
I also use it quite a bit when on the road.
I would not spend the $ to fix the electric one either...but I also won't own a Twin Cam without a warranty, so it is a non-issue for me, will never have to make that choice.
Don't get me wrong, I love having reverse but from what I hear it is about $1800 to fix. A gear driven comes to about the same money. So far knock on wood my reverse is OK, I do not have extended warranty and so far have not needed it. About the time I get my trike out of storage (6 mo), I will have had the it for 5 years. So guess even if I had a 5 year plan I would be out the money I would have paid for the plan.
I'm thinking if Indian ever decides to make a ''Factory'' trike to compete with the tri-glide the'll use a mechanical reverse' Polaris has it on all their 4 wheelers so it won't be too much a stretch for them to do it...Especially if they read the Harley forums and see the problems with the electric reverses..
So, what's "going out" about it? Is the motor getting weak, or is the solenoid not driving the gear into the ring gear, or is the ring gear messed up, have you lost the bearings in the starter motor? I only ask because I recently had the reverse motor in my hand when I replaced my differential. The reverse didn't look like it was very difficult to work on. I've heard many people talk about the price of replacing a bad reverse and I don't understand why it is so expensive to do. We have a motor rebuild shop in town and I think when my reverse goes bad, I will see if they can rebuild the motor for me.
This is why I am riding the Trike as often as I can. Which should be right on through the winter here in TX. Forecast is for warm and dry weather right into spring. I'll take it. As such, one of two things will happen at some point, the electric reverse motor will or will not fail before my two years is up. Should it be after, at that point I will go with the lowest cost replacement. I will by then,be 73. If I am blessed, I will still be riding.
