Changing Exhast on Freewheeler
01-29-2017, 02:02 PM
Has anyone been able to change your pipes on a Freewheeler without removing the body? Can't seem to get at the rear mount.
Thanks
01-29-2017, 03:55 PM
Quote:
Originally Posted by
troopster
Thanks
Yes, it is tight, very tight, but it can be done. We've done it quite a few time.
For removal, remove the rear bolt first, then the front. For install, do the front bolt first, then the rear.
Leave the clamp at the header/slip-on juncture loose for both removal and install.
01-31-2017, 08:57 AM
Thanks! Can you tell me what tool are you using to remove the rear bolts?
Cheers
01-31-2017, 10:29 AM
I use a Craftsman combination wrench, non ratchet type
01-31-2017, 12:49 PM
troopster
Cheers
We use an open end wrench.
02-02-2017, 12:03 AM
I took a grinder to an open end wrench. It is about 1/2 its original thickness. HINT, when re assembling, turn the rubber isolator upside down and do the same with the bar. Now the bolt won't be sitting in a valley, but on top. Much easier to bolt it in.
Geech
11-07-2013 08:06 PM
norcal
Air Suspensions
16
08-22-2012 09:06 PM
KrakkyDoo
Air Suspensions
04-27-2012 06:29 PM
kalamitty
12-23-2011 03:47 PM
itznin
08-23-2006 02:09 PM
