Comfort lift spect.
Received 3,939 Likes
The Comfort Lift™ is a plusher ride than the Standard lift in all circumstances except for the following:
If you are running with no lift kit & the Maximum PSI AND the shocks are regularly bottoming out. This typically only occurs when running over the maximum rider/passenger/luggage of 540 lbs AND on very poor roads.
We have many Customers running a total load of 500-600 lbs, but since they are Not bottoming out regularly, the Comfort Lift™ is preferred for them. However, if load AND road conditions have you bottoming out on a regular basis, it is better to run the Standard Tri-Glide Lift Kit.
Nothing will break, there is no problem running over 540 lbs with the Comfort Lift™.
sascho
07-04-2013 05:47 AM
