Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
forks won't lock
Old 02-23-2017, 11:09 AM
5wheels's Avatar
5wheels
5wheels is offline
Default forks won't lock
I have just purchased a 15 TG. the ignition switch works fine but the forks still move. also cranky going in neutral but understand that should improve with age. just have 75 miles.
Old 02-23-2017, 01:04 PM
Casper's Avatar
Casper
Casper is offline
Try locking the ignition and then turn the forks, they should lock...do this at the dealership just in case they won't unlock....should still be under warranty
Old 02-23-2017, 05:22 PM
rhino 2's Avatar
rhino 2
rhino 2 is offline
Are you turning the ignition switch...All the way to the left, and then locking it with the barrel key..??
Old 02-23-2017, 06:14 PM
Casper's Avatar
Casper
Casper is offline
Ok, is this your first bagger with the ignition lock?
Turn your forks completely to the left, turn the ignition lock to the left to locked position, insert the key and push down, turn to lock.
The ignition stitch and forks should be locked.
Old 02-23-2017, 07:53 PM
Gitarded's Avatar
Gitarded
Gitarded is offline
Be careful the lock mechanism does not pop out on you. If you stumble on the lock removal process.
Old 02-23-2017, 08:14 PM
5wheels's Avatar
5wheels
5wheels is offline
the forks go over and stop. the ignition goes in and locks down it just doesn't lock the forks. otherwise it seems right
Old 02-23-2017, 08:42 PM
Casper's Avatar
Casper
Casper is offline
FYI, you can lock the ignition without locking the forks, the ignition must be turned to the left for the forks to lock
T-town Pig
06-20-2019 11:09 PM
usmc68
09-19-2017 06:57 AM
jfbrown
04-08-2017 11:06 AM
Twillis
09-23-2012 08:21 PM
CrazyMC
04-28-2009 11:30 AM
Quick Reply: forks won't lock
