How Many Flush Their Brakes
I do mine every 2 years, it comes out a little darker then new, but no water.
I don't do anything fancy. I use a clear plastic hose, a box end wrench, a catch container, a turkey baster and my wife. It takes me about 1/2 hr once on the jack and $5.00 for a can of fluid. Again, the "KISS" method. No ABS on my 2011 RK.
I bleed/change brake fluid every 2 years or when the fluid starts to change color a bit.
With the newer synthetic brake fluid it draws moisture more than the older types.
I also use Goodridge speed bleeders to help doing the job alone. They have check valves so you don't have to shut off the bleeder screw on each pump. Just put a clear tube to a 1 liter pop bottle with a hole in the cap for the tube to go through, & all you have to do is keep the reservoir full of fluid & pump the lever.
I used to like the colored fluid so I could change colors each time & tell when the new fluid had flushed clean. But they outlawed it because people were mistaking it for something other than brake fluid.
I use my myti-vac if I had the system open for repairs. Easy to get air pockets out.
Brake systems are too critical to not have in top shape. I believe what you take care of it will in turn take care if you.
Used the engine and transmission most of the time coming down Pikes Peak. I think I touched my brakes maybe twice the whole trip down.
I have noticed some nasty looking brake fluid after a couple of years of use on several bikes. I have changed the fluids of those with no problems. However I am hesitant in messing with the systems that have antilock and or the link brake systems.
The TG 17s have the link system. I don't have a manual yet for this model, but I am curious about the method used for flushing.
