can't find FMV for 2007 tri
I don't think that is a vent on that fairing. I think it is shadows. That Trike is later than '07 also. The trunk is correct for Harley, also the tour pac looks to be correct.
You can put the tru duels on about anything. It has a steering stabilizer & oil cooler also.
Turn signals with smoke lens, rear fenders are correct. The paint just has accent lines, badges removed from tank. The paint looks to be the same red/burgundy as mine (2012).
Also no primary chain inspection hole.
Starting with 06 Dyna and then the rest of the big twin line the primary chain was auto adjust, so no chain inspection hole. I'm in agreement with everyone, it's a Triglide and not an 07 impostor.
FWIW the Lehman Trinity LLS is almost a dead ringer for a Triglide, especially if you equip it with TG wheels.
Yes they did, they also assembled the back half. Harley would build the front half in the York plant and then ship it off to Lehman to have them install the back half. In 2011 HD kicked Lehman to the curb and started complete assembly of the Triglide in the York plant. Unfortunately HD just used Lehman for their ideas and engineering then broke ties, way to many vendors or companies do these things. They use someone else to give them a leg up or just copy their idea and then market them as their own.
