can't find FMV for 2007 tri
Looking for fair market value on a 2007 tri glide w/ 27,000 miles. Forgive me if mess this up, but not sure if it is called a tri glide in 2007. The front end looks like an ultra glide. Can't find value from KBB or NADA. Its like 2007 didnt make 3 wheelers. Can someone help me out?here is a pic of the bike i am looking at for a relative.
*Correction, it has 23,000 miles
Contact Lehman
I'm sure Lehman can give you a good number to start that is a good looking machine. good luck. ride safely Fred
Looking at the picture, did 09 have the left exhaust above the passenger floorboard? Or under like present TG? Also I believe 07 Ultra had front lollipop front turn signals.
It also shows a vented front fairing, strange. Have you seen the trike in person? Or over internet?
Careful of scams
Careful of scams
I agree with others that it has to be a custom. A 2007 ultra with that low of miles, and if it looks as good in person as it does in that photo, would be probably worth at least $16,000 or more. Just a regular 2007 Ultra is valued around $10,000 in good shape so this one would certainly bring more to a private party. Trade in value would be a different story.
Careful of scams
Careful of scams
I will say the seat looks correct for an 09 and later Triglide, I wonder if someone is just confused as to what the correct year is. Maybe the title has a typo or isn't very legible. I believe some true dual exhaust exit like the old style exhaust, maybe it has duels.
I believe a VIN check would be in order
Starting with the 09 Touring and Trike, the rear exhaust pipe was located to run under the frame. Pre 09 it exhausted above the passenger floorboard, yes the front turn signals on an 07 are the lollipop versions. The OP could be showing the picture of someone who did a pretty good Triglide knock off. It has the correct rims and turn signals. If it is an 07 it will have a crossover line joining the 2 fuel tank halves.
It's a great looking ride, they need to check the vin that will clear up a lot of questions. Fearless
ISP-FLHTK (03-16-2017)
