Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Tri-Glide Issues
Old 08-21-2014, 10:05 PM
Oogie Wa Wa's Avatar
Oogie Wa Wa
Oogie Wa Wa is offline
This was definitely the button and latch operating slowly, you could pull the button out physically to help it. We have not had a single instance of it opening after ensuring that the button is all the way out. Although those are both great pieces of advice. Thanks!
  #452
Old 09-17-2014, 01:07 PM
TrapshooterBob's Avatar
TrapshooterBob
TrapshooterBob is offline
New recall to rebuild master cyclinder replacing rubber boot which might tear and cause clutch to not disengage.
http://www.harley-davidson.com/conte...e-recalls.html
  #453
Old 09-17-2014, 04:07 PM
mwessel's Avatar
mwessel
mwessel is offline
Yep, have an appt tomorrow for my fix. HD shop will have it done in 20 minutes. So I'm told.
  #454
Old 09-17-2014, 04:26 PM
GARY DYER's Avatar
GARY DYER
GARY DYER is offline
I'm on it too.
  #455
Old 10-30-2014, 11:59 AM
Indpthwill's Avatar
Indpthwill
Indpthwill is offline
Stage II
Default Here are mine
Trunk lid will open during riding
Check engine light has an attitude ad decides when and where to turn on; will not turn on at the dealer--it knows.
When the engine shifts to its "heat safe" mode; the engine sounds like it wants to die and the voltage drops significantly--especially with both fans on.
2014 Trike Ultra Classic
  #456
Old 11-09-2014, 11:54 AM
Fatzboobaloo's Avatar
Fatzboobaloo
Fatzboobaloo is offline
Stage II
Found that when closing trunk hold in button latch close lid and release button..Might cure what ails ya...Ride safe...
Bob McGee (05-14-2016)
  #457
Old 11-09-2014, 04:56 PM
sullyj020's Avatar
sullyj020
sullyj020 is offline
And it's best to lock it. I had the same issue.
  #458
Old 11-14-2014, 03:47 PM
rugerman63's Avatar
rugerman63
rugerman63 is offline
LITTLE WD-40 DOES WONDERS
the rubber seal around the button is holding it from coming back out, try some lub
  #459
Old 02-01-2015, 05:30 PM
Watco2's Avatar
Watco2
Watco2 is offline
Stage II
My trunk keep coming open on my 2015 tri glide, even after the dealer adjusted it, with the trunk locked. I decided to tackle it myself. Loosened the nut and then backed up on the stud to make it a little longer, then tightned the nut. Adjusted it this way
a few times untill it closed easily with no back and forth play in the door. Seemed to do the trick. Rode the rest of the day and hit a lot of RR tracks, so good so far
  #460
Old 02-01-2015, 09:49 PM
tmigala's Avatar
tmigala
tmigala is offline
Make sure you still have it snug enough what it crushes the gasket enough to keep water out.
Quick Reply: Tri-Glide Issues
