Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
PM (Performance Machine) TG Brakes Installed
Old 04-21-2010, 10:07 PM
PopDukes's Avatar
PopDukes
PopDukes is offline
Default PM (Performance Machine) TG Brakes Installed
WOW. What a difference. Not only did it rid my squeaking, but most importantly, the TG now stops on a dime!
Dramatic improvement on stopping ability!!!!!! Feel it was well worth the investment. About $1500.
Old 04-21-2010, 11:25 PM
SEAlaskan's Avatar
SEAlaskan
SEAlaskan is offline
Stopping on a dime, eh!! front and rear brakes together I assume?? How much of a improvement on rears only
Old 04-22-2010, 04:45 AM
oldmsocko's Avatar
oldmsocko
oldmsocko is offline
Very good question. With my stock brakes using front and rear at the same time it will stop on a dime. My stock rear brakes appear adequate, but as soon as Lyndell come out with rear brake pads I will replace my stock pads with them.
Old 04-22-2010, 06:35 AM
msocko3's Avatar
msocko3
msocko3 is offline
... Just saying.
Old 04-22-2010, 06:36 AM
Boom's Avatar
Boom
Boom is offline
I guess I can say the same for my '10. One thing that urks me is having to "stand" on the rear brake at a stop to keep it from drifting. I like to sit back and stretch without having to grip the front brake.
They changed the rear brakes on the '10s???
Old 04-22-2010, 12:58 PM
carlo's Avatar
carlo
carlo is offline
$1,500 is a lot of money for a up grade when will it stop. My 09 TG stops fine.
Old 04-23-2010, 03:37 AM
msocko3's Avatar
msocko3
msocko3 is offline
One of the bullet items in the 2010 MY technical update says the following for the Triglide.
Reduced Rear Brake Effort
(New Master Cylinder and Calipers – will retro-fit)
Myself I can't feel any difference between mine or my dads rear breaks. I can say for kicks I decided to see what the rear breaks would do one mine when I pushed harder than normal on the peddle. I was surprised at how loud the rear tires squeal when they lock up. I figure if you can lock up the back tires you can't ask for much better breaking. To me it doesn't seem like I have to push very hard on the rear break peddle to stop or hold it while sitting at a stop light, but everyone has different physical limitations. Maybe there are some who need reduced effort due to leg strength issues, I used to squat 500# at one time so I don't have much problem in that dept.
Old 04-23-2010, 04:40 AM
oldmsocko's Avatar
oldmsocko
That's not very much weight. I use that much just to warm up.
Old 04-23-2010, 08:48 AM
Boom's Avatar
Boom
Boom is offline
500 lbs.?! Geez, more like 500 oz. for me!
Old 04-23-2010, 10:06 AM
SEAlaskan's Avatar
SEAlaskan
I haven't been able to lock up my rears on the '09 TG. Maybe I have to look into the retro's. Most of my braking is with the fronts except in hard cornering then I use the rears only, which you don't want to lock them up.
Quick Reply: PM (Performance Machine) TG Brakes Installed
