Road Chips on TG
I'm concerned about getting small stones in my belt. Also took my seat off one day to find a small stone must of come off my boot and found it's way between the seat and gas tank. Causing the paint to rub off leaving a good size pock mark. I cleaned it up best I could and put clear coat paint on to mark to prevent rust.
I met a retired engineer here in Denver that worked for Gates Tire and Rubber Company. He was in on the R & D work for the rubber drive belt we have on our motorcycles today. He was a real interesting person to talk with. I ask how they tested the first belts and he said they had a big Harley pushed up against a wall, would hold the throttle wide open and drop the clutch. He said they broke a lot of belts but eventually had a prototype that would work and not break. Kool old dude!
I had Champion install the 3m film on my fenders when I bought the kit as I had it pre-painted to match the bike. Not cheap but IMO well worth every penny. The front of the fenders catch a lot of small road debris but the film is tough enough to prevent dings and isn't even visible from a few feet from the trike. The great thing is that when it does get dinged up it can be removed and replaced.
+1 on the 3M film. You are correct. It is not cheap.
Though I built my Trike. I still get the problems you guys are experiencing. !st off. The simple fix for where that chipping is taking place on the bottom edge of the body between the pipes would be the door trim guard for autos. What I see thats happening there. Is when the paint was applied to the body. They didnt spray underneath that edge. but sprayed just the outside of the body. A full length mud flap would prevent that from happening.
As for the gravel that finds it's way in between the pulley and the belt. Back in the days of old. I had a triumph motorcycle. Though it wasnt belt drive, but chain drive. The chain and sprocket had an enclosed chain guard covering it. I plan on making an enclosure for mine and if I can. Ill make them available for the belt drives as well. Upon closer examination of my belt and pulley. The gravel that did get trapped in there had put nicks in teeth of my pulley.
zoood
zoood
The only reason the trike has chipped paint was cause I isn't bright enough to realize that would be a problem till the "happening". So now my fenders are needing a paint job. I'd like to two tone this trike some day.
Ride the snot out of it "YOU BET" I love this machine. It's quick on the corners, comfortable, just needs a little more grunt in but not much more or I would be in serious trouble. Love it.
Butch
Butch
