Fullsac vs Jackpot Tri Glide Head pipes
#91
Just to be fair and since this is a Fullsac comparison to Jackpot X pipe thread...
These two pipes are not the same, not built the same nor handle the rider heat the same but they both preform very well for TQ and HP increase.
The pipe materials are different, the collector is made differently as well as the construction of the pipe and the addition or lack of material coating if you need the coating.
Politically correctness seems to be the "in" thing these days and I think we all try to influence new purchasers with their decisions without influencing them. (I could get tongue tied trying to say that fast) It's a fine line we tend to walk.
We all use very similar equipment to get our similar end result but the end result has to be to our personal taste and preference. The bottom line is to be happy with your decision after the purchase and installation.
#92
Aftermarket
#93
Thanks a lot for the info! I understand the need for being politically correct. It is a very litigious world out there. I see so many different setups in the signatures, so it really is a personal choice. Some may have been timing/availability which is understandable. I have a few weeks yet to make my mind up
#94
Well said and it's gonna be a big tent after the next round of EPA standards roll out. We had a backlog and some wait time early on for the stainless pipes. I believe there will be room for everybody and then some, competition is healthy and we need em all in the game to help work around the EPA.
#95
Cheap Cult
In an era of $4.00 a gallon gas and bikes that cost as much as loaded up pickup trucks, I think I am gathering a cult following! We are always looking for the deal!
#97
#98
Three Ring Circus
I meant as for aftermarket exhaust, Fuel Managment Systems anything that that will work around the EPA killing HP and causing heat related problems. There is enough room in the market for several different manufacturers of aftermarket exhaust pipes. About anybody from 2010 on will be dumping the cat so sales should be brisk.
Subconsciously I think it's a friggin Three Ring Circus, buying bikes off the show room floor and having to drop another 2 or 3 thousand to make the things run, or keep from melting down!
#99
