2011 Triglide trailer hitch
#62
RIVCO makes a hitch for the 2011 Tri-Glides the part number is HD007-TG11 it sells for $299.95 and comes with a plug and play wire harness (you still need to purchase a trailer plug set). If you have a 5 wire trailer with LED lights the harness supplied with the hitch and a trailer plug set is all you need. If you trailer is a 4 wire system you will need to purchase a 5 to 4 wire converter (RIVCO part number EC07664 $29.95). If your trailer has regular filament style light bulbs rather than LED lights you will also need to purchase an isolator to keep from overloading your bike's wiring (RIVCO part number GL18007-IU $69.95). The 5 to 4 wire converter must be installed before the Isolator, and the plugs will have to cut off othe Isolator and 5 to 4 wire converter and the units will have to be wired in. RIVCO provides a detailed wire diagram with the isolator.
#63
dogwheat
01-19-2014 04:41 PM
