Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Transmission Sprocket Change Begins
Old 11-22-2010, 02:39 PM
Boom's Avatar
Boom
Boom is offline
Originally Posted by oldmsocko
You are %100 correct. There is nothing wrong with adjustable push rods we just elect not to use them.
I like the way you guys work----methodical, take your time, bag it and put everything in its place. Also taping and covering everything. Lord knows the regrettable things I've done in the past by rushing to finish and dinging or scratching something that is expensive to replace! I already have a scratch in a new Clearview windshield and don't know how it got there! Probably cleaned it with a dirty rag at one time.
Old 11-22-2010, 05:33 PM
0734's Avatar
0734
0734 is offline
Would anybody believe I have the market cornered on 30-tooth sprockets and purchased 50 of them when I heard the rush-is-on....?
Nah.....just kidding. But, I am not kidding about this part. I recently changed sprockets and set my belt tension...etc. After a 600-mile trip I checked my belt tension when I got home. It was pretty loose. I suppose if you don't have many miles on your stock belt and sprocket...there won't be much run-in. I had several thousand miles on mine and I suppose the old belt had to run-into the new sprocket....or vice-versa. I know you guys routinley keep a check on belt tension, but this is just a heads-up to check it again after you burn-in the new sprocket. We all know what a PITA it is to set the belt tension on a trike.
Old 11-22-2010, 08:36 PM
0734's Avatar
0734
0734 is offline
This must be my night to run-on-at-the-mouth, but I failed to mention something 3 brought up. It's fairly common knowledge that the MOCO auto chain tensioner can be a problem child. Some of the Harley Techs. that I know and trust think it runs the chain too tight...and I do too.
If you decide to toss it, there are some good alternatives out there and I am not taking sides on any of them, but I have been running the Hayden M6 for years and years in both the EVO and the TC. They don't have the ratchet mechanism that Harley (over complicated) built into theirs. It's spring loaded and while applying serious tension to the chain, it does not run as tight as the stock MOCO tensioner. I have not really heard any TG owners complain, but maybe the other complaints and fixes have kept everyone busy and nobody has trickled-down to the tensioner yet. While I had it down....I'd stick another good tensioner in there.
Old 11-23-2010, 03:14 AM
msocko3's Avatar
msocko3
msocko3 is offline
I checked the Hayden site and they don't make on to fit 07 and newer so we're out of luck there. I'm still tossing around the one I mentioned in my first post.
Old 11-24-2010, 04:30 AM
oldmsocko's Avatar
oldmsocko
oldmsocko is offline
Originally Posted by icebite1
M3, we kinda hijacked your thread a bit while waiting for the next installment of pics on the pulley change, you know we are waiting to see what kinda wrench setup you are using to get the nasty nut off .
We purchased the required socket, belt locking tool, and a 3/4" ( 40" ) breaker bar. Will post photos shortly. He is taking a break as his place of employment scheduled him in on his days off. Had to get some extra cash for all the extra tools needed.
Old 11-24-2010, 09:25 AM
icebite1's Avatar
icebite1
icebite1 is offline
Just a note on the socket to remove the pulley nut. I have seen some of these sockets come with 1/2" drive instead of 3/4", mine is the 1/2", that is why i used a pipe wrench and cheater bar. It worked perfectly on 3 instalations. The 1/2" drive is ok for your pre torque but no way are you going to final torque or get that nut off using 1/2". Now with that said I perfer the 1/2" drive as i dont have to add 3/4" drive accessorys to my box.
Baires52 (07-06-2023)
Old 11-24-2010, 11:23 AM
oldmsocko's Avatar
oldmsocko
That makes perfect sense to me.
Old 11-24-2010, 11:43 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,541 Likes on 3,793 Posts
Originally Posted by msocko3
This is a picture of the compensator sprocket and ramps. I was interested to see how the sprocket would look. There had been guys seeing some gulling where the ramps run on the sprocket, mine is showing some of this gulling.
Shot of the primary with everything removed.
When I look at your sprocket at 12 o-clock I know you refer to galling but is that a wear area or is the notch from a machining process Harley did to it? I assume this is an SE compensator but mine (regular one) at 35K looked like it had just been cast. Appears the trike puts a lot of load on it or it's not heat treated correctly.
1966 Electra Glide (07-07-2019)
Old 11-24-2010, 02:07 PM
coupe55's Avatar
coupe55
coupe55 is offline
Default metal in oil?
Don't look that bad in the pic, I imagine mine would look better at just 5000 but that Tri has been rode a little harder. Unless there is a lot of metal in the oil I don't believe it would be a concern but you can't really tell by pics on the internet.
I've seen worse with no problems, any noise before it was pulled?
I thought the 09-10 tri's had the SE compensator so it may be forged instead of cast. Case hardening is just a few microns thick on the surface, looks a little shinny where the carbon wore off on the gear, normal wear?
Old 11-24-2010, 02:54 PM
msocko3's Avatar
msocko3
msocko3 is offline
It is a wear area, the picture doesn't show all the gouging that it has. I have read threads other places where guys were seeing the same things on their SE compensator which the Triglide is equipped with.
Quick Reply: Transmission Sprocket Change Begins
