Reverse Relay
Hey Bronxbill,
On a different note, how's the Fuel Moto package working for you with the PCV? I'm leaning that way, just not sure of what to use for fuel management. The Cobra FI2000 looks interesting. Over the years I've gotten tired of playing with SERT, TTS, etc.
How close was the map that Jamie set you up with? Pro's & Con's before I spend the big bucks.
Delta,
I'm very happy with the map installed by Fuelmoto in my PCV. Trike runs great and I have no problems. Just be aware that the PCV does require that you disconnect the 02 sensors. The good news with Fuelmoto is that if you make any further changes they will update your map for you for free. I did try using the tuned slip ons as they came from Fuelmoto, but I ended up installing the quiet baffle. My passenger complained about the sound being to loud in the rear with the stock baffle. It sounded fine to me, so you may want to judge for yourself
I too was confused about connect/disconnect of O2 sensors. Had to call the Fuelmoto guys to find out. I was told O2 sensors are installed in the new pipe (for future use like Autotune) but disconnected. If they are connected, this defeats the purpose of the PC V and its map.
If you want to try a test, unplug the sensors from their respective connectors under the right panel and see how it runs. Just tape over the connector openings so you don't get any crap in the pin holes. Also tie-wrap the cables out of the way. My TG runs better with PC V connected and no O2 sensors.
kyleplusitunes
12-27-2011 04:57 PM
