Help! Can't find neutral
Hi,
With 600 km of triking with my new Tri glide picked up on Monday, gotta say, frustrating that while engine is running, can not get the Trike in neutral. Course, neutral is where you need to be to reverse!
I can remedy the problem, by shutting off the engine, clicking easily into neutral, and slide I to reverse. But....um, it looks ridiculous! Everybody watches the Tri glide, so it's rather embarrassing to not be able to find neutral with engine running!
The dealership says it will loosen in time!
Please help!
Please help!
Purple
With clutch handle pulled in all the way, move the trike a little back and forth with you right foot, while gentley shift to neutrual with your left foot. You will get use to finding it this way. It will be easier with time. keep in mind to MOVE/ROCK it a little. Good luck.
I also had the same frustration finding neutral at first, even with the rocking back and forth did not help much. I also resorted to shutting engine off and found neutral that way.
I read here on the forum about using REDLINE heavy in the tranny and man, what a difference! It shifted so smoothly in every gear and almost felt like I didn't need to pull the clutch in. And finding neutral was so easy after that first 1000 mile service.
These folks in this forum are a boatful for information, thanks guys and gals!
RR1
RR1
