Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Trike Running Boards
Old 06-29-2011, 09:37 AM
writeman's Avatar
writeman
writeman is offline
Default Trike Running Boards
Anyone else have the Harley running boards from Lehman's? What is you opinion of them other than expensive?
Attached Thumbnails Trike Running Boards-img_49.jpg   Trike Running Boards-img_54.jpg
Old 06-29-2011, 12:25 PM
Bubba49's Avatar
Bubba49
Bubba49 is offline
I wonder how they affect the airflow to the engine? Looks like they would hamper in a litle bit.
Bubba
Old 06-29-2011, 04:38 PM
rgc's Avatar
rgc
rgc is offline
4th Gear
Default Running Boards
I have mine on ... biggest problem is getting the dealer to install them correctly ... the boards give you some cushion from road heat and noise ... the boards seem to keep engine noise from bouncing off the road and back up and there is a considerable shifting of noise to behind the trike ... the boards are a bit pricy but look good ... they do not seem to interfear with air flow to the engine ...
Old 07-01-2011, 11:04 AM
writeman's Avatar
writeman
writeman is offline
There is enough air gaps along the inside of the boards to vent the engine. I had mine done by a local Three wheeler dealer and he didn't have a problem. The problem I had was when I had the Legend Air Suspension installed, the bracket from the running boards interfere with the brackets from the on board air compressor. The dealer had to make some brackets for the compressor.
rtbuck89
General Topics/Tech Tips
05-06-2018 05:49 PM
unnnivers
EVO
08-22-2014 09:02 AM
DEVILDOG1371
01-28-2014 10:09 PM
the4thgearkid
06-02-2013 02:51 PM
missboy
05-15-2011 10:25 AM
Quick Reply: Trike Running Boards
