Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Factory vs Conversion Kits
Old 12-19-2011, 03:18 PM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Administrator
Received 2,036 Likes on 1,104 Posts
Politeness is a southern thang.
I even call my son's sir. Freaks them out.
  #32
Old 12-19-2011, 04:03 PM
Bigfoot1's Avatar
Bigfoot1
Bigfoot1 is offline
That's good! I'll hafta try that with the ol ladys kid!
  #33
Old 12-19-2011, 06:18 PM
oldmsocko's Avatar
oldmsocko
oldmsocko is offline
You never called me sir, just Boomer. Is that because you are older than I.
  #34
Old 12-19-2011, 06:22 PM
oldmsocko's Avatar
oldmsocko
Can I play too?
Forgive my memory, it isn't that great, but seems both conversations have a lot of the truth.
I'm thinking that HD sent an incomplete build to Lehman where they installed their swing arm assembly and body then sent it back to HD for shipping to their dealerships. This was in 2009 and 2010. 2011 HD took over the complete process.
The frame for the TG is different than a UC from the end of the tank back if you look at them stripped down as I have. The frame is a little different under the seat to the swing arm attachments. Wouldn't this make the TG frame a trike only frame?
It's amazing how much incorrect information there is out there about the TG whether it is a conversion or not because Lehman put the back half on it.
  #35
Old 12-20-2011, 08:54 AM
coupe55's Avatar
coupe55
coupe55 is offline
Default Factory Built
Am I correct with the notion that HD does the Tri Glide in house now at their Milwaukie Plant, does not have an affiliation with Lehman now! I believe this started with the 2011 model!
  #36
Old 12-20-2011, 11:10 AM
bronxbill's Avatar
bronxbill
bronxbill is offline
HD does it in house at the York plant.
  #37
Old 12-20-2011, 01:55 PM
msocko3's Avatar
msocko3
msocko3 is offline
You are correct, 2011 is the 1st year the entire build of the Triglide takes place in York.
  #38
Old 12-20-2011, 04:42 PM
busterman2's Avatar
busterman2
busterman2 is offline
Does the Tri Glide frame have a different part number from the standard touring frame? Does the Tri Glide frame have a different neck rake than a touring frame. It is my understanding Harley uses a raked tree (like a conversion trike) with a different part number from the standard solo touring tree.
  #39
Old 12-21-2011, 06:13 AM
msocko3's Avatar
msocko3
msocko3 is offline
Frame part numbers are different, PN for a Triglide frame is 83411-09BHP and the PN for the FL 2 wheeler frame is 47900-09BHP. I believe they both have the same rake at the neck, with the Trigide getting its rake from the trees.
  #40
Old 12-23-2011, 08:42 PM
Frostbite's Avatar
Frostbite
Frostbite is online now
Received 3,444 Likes on 1,558 Posts
Originally Posted by Bigfoot1
.... NOW, it's snowin here, gonna get the 07 SE trike out an see how the BFG's get me around. As long as the boss isn't lookin!
Tried that last week - the getting around wasn't bad, the STOPPING....well, that's another story. Leave yourself lot's of room!
Quick Reply: Factory vs Conversion Kits
