If you are refering to the pinch bolts it is 53-57 ftlbs.
You have probably heard it befor but if you are going to do your own wrenching you really should buy the service manual.
Thanks! I have a street glide and putting a set of Tri Glide tree's on so I can run a larger front wheel. I do have the service manual for the street Glide
The TG trees have more rake than the SG, you may have instability/low speed wobble with or without the damper.
The have a few guy that are using them on there SG with a 23" wheel and they say it rides good. I guess we will see Im looking farward to trying it out. Thanks for the heads up
