Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Rear caliper piston compression
Old 09-27-2012, 01:29 PM
yukon1's Avatar
yukon1
yukon1 is offline
Stage II
Default Rear caliper piston compression
I am placing rear brakes on my 2009 trike. I have tried to compress the piston on the left side caliper, the one with the parking brake attached. I can compress the piston but not all of the way in order to replace the brake pads. The piston acts as if there is pressure still on it someplace. Is there something I should do to relieve the pressure or do something to the parking brake. Any suggestions would be appreciated.
Old 09-27-2012, 02:57 PM
sloufoot's Avatar
sloufoot
sloufoot is offline
Moderator
Received 4,082 Likes on 3,484 Posts
You need to back off the adjuster for your hand brake. At the calipers. Then re-adjust !
You need to get a shop manual, along with the Trike supplement. They are valuable books if you are going to do even maintenance on your bike ! Best money you can invest !!
The Wiz may have the whole thing on here somewhere. Do a search.
bagga
04-14-2019 11:28 AM
scottypeeze
06-01-2018 04:08 PM
RocketyMan
09-08-2017 04:31 PM
relli
08-19-2013 02:55 PM
clarsen2020
Wheels/Tires
07-22-2010 07:32 AM
Quick Reply: Rear caliper piston compression
