Led Tail Light Bulbs for 2012 Triglide
I hate to say this, but any one checking this thread for hyper-flashing on a tri glide, be sure to install both brightasslights before checking function. I didn't want to open the 2nd box incase there was a problem. I even installed the tour pak converter, and that didn't fix the hyper-flashing. After E-mail from BAL this morning, they said "both lights needed to be installed and bike running to check function, if hyper-flashing still present, then try the simple turn signal conversion for the tour pak, or add load equalizer to draw more current". After I installed 2nd BAL, I had no hyper-flashing, I unpluged the tour pak, and still no hyper-flashing, so guess I didn't need converson but I do like it.
I feel so stupid!
I feel so stupid!
All set, except tour box liner is raised slightly, because of wire going at angle from grommet to right rear tour pak bulb housing. Conduit bundle need to be 3 to 4 inches longer so it can lay in the trouth around inside bottom of tour pak. Pulled all cables tight and still too short. Called local Harley and they said that is a problem. Thinking of mounting under left bulb housing and switching wires. Going to sleep on it. Raining here in Indiana so I can't ride any way.
I don't know why everyone has to buy ready made everything....
