upping tires size on rear tires
This is what I did, I replaced rear tires on TG with 225/75R15. Raised TG 1.4 inches. Handling greatly improved. She does need to have new cams for sure now. She will get S&S 557 cams 2 July and will dyno 9 July with TTS tuner. The ride is a lot easier on the butt and back. Running 21 # pressure in tire. Just finished 250 miles on her. Going to is how 24# feels in her and add some more dyna beads for balancing. Only had 6oz so put 3 in each tire. Will add 1oz more to each and 2oz to front. with new tire gear ratio should be closet to the ultra. 10% increase over all gears. done at the tires and speedometer is 10% under actual now.
Always a Marine
Mickael
Always a Marine
Mickael
Good luck with your tire change. You have now changed your final drive ratio to worse than the '09 & '10 MYs.
Speedometer Difference (Speedo Reading / Actual Speed) 20 mph / 22.19 mph ,25 mph / 27.74 mph 30 mph / 33.,29 mph ,35 mph / 38.84 mph ,40 mph / 44.39 mph ,45 mph / 49.93 mph ,50 mph / 55.48 mph ,55 mph / 61.03 mph , 60 mph / 66.58 mph , 65 mph / 72.13 mph
Side by sideOverlay
Maybe a dumb question but i am getting ready to trike my 09 ultra. I am planning on a 18" preformance machine front wheel with a 130/70/18 Dunlop Elite 3 Touring Tire on it. On the rear I will be using a 17 x 5 preformance machine wheels. The trike body manufacture usually put 225/60r15 on but I am looking at using Dunlop Direzza DZ 101 tires that are sized 245/45r17.. Not to worried about the speedo due to having Medallion Gauges that I can setup/ recalculate using my GPS. Question is will I encounter some of the same that you all are talking about as far as Power?
But, you will probably feel/be underpowered with the 32 tooth primary pulley. That is why most of us changed to the 30 tooth pulley which is standard on the '11 and up TriGlides.
Side by sideOverlay
