New Tri-Glide Owner With Questions
Just got our 2013 Tri-Glide and was wondering about a Stage 1 on it. How much of a difference am I looking at putting on some pipes with this versus my old 08 Ultra? I am pretty limited on what I can do (I am on kidney dialysis) so is this a pretty extensive job?
Also I have a J&S jack, which won't work on this Tri-Glide (of course..), so any suggestions on how to jack up the trike for cleaning and general maintenance? The trike version J&S is fairly expensive so that will be awhile. Thanks for any help!
Rax
Rax
Stage 1 mods on your trike will probably be the same as for a solo and your jack will lift the front up when you need to. There is plenty of info on doing a stage 1 in here, although IMHO much of it isn't as helpful as it can be! With the EPA restrictions on current Harleys I think I would be looking at going beyond a stage 1, by adding cams as well, plus a tuner - to solve the emissions problems and give it some extra zip!
Bubba
Rax
Rax
This works for getting under the trike without having anything in the way. I am building a lift for the trike, but it isn't finished. The ramps raise the trike up to a level I can set on a roll-around work stool (short) & reach everything with ease.
Rax
Rax
As far as the mods you're speaking of, yes they are going to be pricey. You can start out with just changing he mufflers and you won't have to reprogram the EFI. Once you change the Air Cleaner then you will have to get some kind of tuner. If you really want to cut down on the right side heat then your next mod would be to change out the headers. The last mod would be changing the CAM. For a trike most owners have been going with a Torque CAM.
Sorry to hear you're on dialysis. Hope everything works out down the line.
I put the Kuryakin Perfect Storm kit on my '12 TG. Headers and mufflers are sourced from Vance & Hines. You also get the upgraded air cleaner and a TT MasterTune set-up. It saves you a couple hundred bucks on buying the stuff separately, and makes a HUGE difference in performance and the heat issue.
After that mod, I got the shock lifts and TourPac relocator rails from tglidestuff.com I would strongly recommend these mods/upgrades to ALL TG owners. The sooner you make these mods, the happier you'll be.
So changing the air filter and exhaust, as well as cams, will remove the bulk of the EPA stuff and make the bike noisier, but will cure the heat and with a tuner plus cams give improved performance. The tuner will allow better ignition timing and fuelling settings to be used. For a trike the most suitable cam may be different to a solo and the chaps in here can probably give a good recommendation.
IMHO our new bikes are so badly compromised by EPA regulations that a 'stage 1' really should include new cams these days.
