Tri-Glide Issues-2014 Trikes And Newer Rushmore Trikes
#171
#173
#175
#176
I have 2015 tri-glide now and have problems with the brakes pulsing when you use the rear brake peddle. The brakes are linked on the 2014 and 2015 Tri-glides. had a 2014 had no problems with brakes on it. Harley did come out with a New rear master cylinder recall but how do get them to make sure they check the rotors to make sure they are not warped. just wanted to see if any one has issues with this. thanks
#177
I have a 2014 with about 2600 miles on it. The only problem I had was that the button for the trunk popped out. I love it and I'm having trouble getting my wife off of it. She was never a fan of my bikes, but she is in love with this Tri-glide. No coolant issues at all [Murphy's law says that I'll have trouble now that I said that.]
#178
Hi my name is Rich. I purchased a 2014 last yearr and then had to have a cancer operation, I am doing a lot better now. It has been almost a year and the doc thinks i am doing good. I have started to get out on my trike now that the weather is getting nice. I am getting use to switching from 2 wheels to 3 wheels. My question is i am still have some issues with making turns with the bike. I seem to be getting better making the turns, but sometimes i end up going straight rather than making the turn. Any advice on how to improve my turns would be very much appreciated
Thanks
Rung
Thanks
Rung
#179
Thanks
Rung
Thanks
Rung
Practice, Practice, Practice as they use to tell me. If you can find an empty parking lot perhaps a church lot during the week go there and practice. You sure don't want to be out in traffic and not be able to make a turn you need to make.
Glad you are doing better and feel like riding again. Practicing might seem boring but it can save your life in the long run. While your practicing turns try some emergency stops. Everything you do will help you.
Are you comfortable with the ergonomics of the trike when sitting still? Maybe some adjustments are needed if not. Good luck and let us hear back from you as you progress.
#180
