Another Cam thread
#291
#292
Why Change lifters anyway?
Question about the 875 lifter we use them often in the shop they are a limited travel lifter that require more precise valve adjustment and are designed for higher RPM hyd roller cams. I had not planned on adjustable push rods with this cam change. Since it can tolerate more plunger travel or preload tolerance if you will do you think a OEM replacement 850 lifter be a better choice?
Why is everyone changing lifters anyway. The TTS-100 isn't a high RPM hot rod cam. My driving style is always between 2000 & 4000 RPM why not just use the stock lifters with 8000 miles on them
#293
#294
I heard from a reliable source that the TTS 150 cams run really well in a 110 but are not quite as impressive in a 103. He still suggests the TTS100s for a stock displacement and head 103. My TTS 100s go in in two weeks. I will post the results. Looking forward to it!
#295
#297
#298
who da thunk it..... I've run the 222 cam in a FatBoy, the 555 cam in a Street Glide, and a Harley 585 cam with a Stage III pro kit in my '15 RGS, I may have to try this TTS-100 in the trike. It appears that I should consider some oil distribution improvements as well
#300
