Another Cam thread
#321
Mr. Wizard (05-03-2016)
#322
Hey Wiz, I continued this conversation over here since it's probably more appropriate in the thread about TTS-100 cams and tuning them. I went to -3 deg at WOT, and just like you said, it's very happy. Very warm day, high was 90 deg. Since making that final tweak, no knock retard events at all over 6 recording sessions. I hit the throttle pretty hard in 4th, 5th, and 6th gear and it ran great. Getting 28 mpg at 75 mph, and 33 mpg at 55 mph. I think I got Big Blue's mind right!
#323
#324
#326
+1 on the nice ride IB.
I can't tell you what to buy but others who have used that cam are jumping up and down happy. I've heard it has been used in 96 to 110 with pleasant results in bottom end and midrange where we three wheel boys ride...
I've searched the web to find other reviews or negativity... nada, zip, nothing...
#327
Thanks Mike and Dave. I have also been searching web for info without much results either. I might take the TW555 out of wife TG to use in my RK and replace with the TTS100. I know the 555 will work good in the 96" and the tts100 might be a better match for her 107". Then again I kinda hate to mess with the TG as it really runs great as is. Guess I have to do more thinking. Right now I have the RK primary out and am replacing with SE Comp, Hayden tensioner, Barnett +1 and a heavier clutch spring along with Clutch Wiz just like in her TG. One thing I haven't changed is the primary pulley , I gained 300rpm by using smaller diameter rear tires so 6th gear seems just about right so far.
#328
#329
#330
You probably have your answer, keep the Triglide as it is and install the TTS100's in your new trike. IMO that's the direction I would head.
