Front tire mileage
I currently have 17,000 and getting close. I ride fairly hard in the turns, and have lift kit that places a bit more down force on front tire.
I Have purchased OEM (same) tire at Harley dealer, and will have put on soon.
I am down to 0.02 considered OK but in the yellow range right now. I expect to put another 3K max this year. So just watching it, and the conditions I ride in. If I were to ride in lots of Rain, I would have replaced now.
So answer in short, you could easily get 20,000 miles on the front tire depending on how you ride, and conditions of riding.
Last edited by Fusionfool; 09-29-2014 at 07:11 PM. Reason: corrected from 0.2 to 0.02 opps missed a digit.
We've gotten 15k to 20k on the 2010 & 2012 tg's front tires, depending on the type of roads. On this 2014 at 10k service they said it's got about 2or3k left & were probable right. So I had them put a new dunlap as usual on, as I was leaving for a 6k road trip & didn't want to worry.
I have heard from others that they aren't getting as many miles on the 2014's.
Could it be due to rear brakes are now link with front? I don't know?
Rear Tire Backwards
Maybe I can help, no promises. A rear tire is built to withstand acceleration forces. A front tire is built to withstand braking forces. Many of today's new rear tires are built with a harder center rubber with softer rubber on the outside edges. In turns, this softer rubber grips really well while in a straight line, the hard rubber in the center lasts longer. Now having said this, if you mount a rear tire in reverse and put it on the front, you have reversed the acceleration forces and now it is in the direction to withstand the braking forces. Make any sense so far? On a trike or a hack the tire/road surface patch is only in the center of the tire giving higher wear on the center hard rubber. The only negative so far is the tread pattern. Normally a tire tread is designed to channel the water away from the tire. In theory, you lose this. I have never had a problem with hydroplaning, not saying you will or will not. I have done this in the past on side-car rigs and two trikes. I wish you the best, just keep in mind that I'm not a tire engineer. You can go to Michelin and other tire manufacturer sites and find similar information.
Stay safe. Ride safe.
Also periodically check & torque the lug nuts to specs. There have been trikes loose rear wheels from never checking them. Never just trust the dealer to do so !
