Am I Fueling Up Wrong?
This is what I did. https://www.hdforums.com/forum/tri-g...l#post11522292 . Makes it like the old style steel filler neck with vent holes to get rid of the air pocket. I dont care if you do this or not but has been working for us. Just remember that if you run the pump at full speed to the end you will get splash back here also, this just lets you finish the fill like the older style tanks without having to dribble the last 2 or 3 gallons in.
Are you totally ignorant or don't you have anything else to do but make stupid remarks on something you know nothing about. You have been urinating down the side of too many urinals as you suggest your expertise is by your post #10 in this thread, just eat that cow you cant get rid of and maybe your mouth wount get away from you. We know you cant afford a TriGlide or a new bike, yes ive read some of your previous posts, so next time you post try to have something constructive say and stay on subject so as not belittle your self any farther. Oh, you do know this is the TriGlide section of the forum don't you? Now I fully expect you to have another stupid response to this post to which I am going ignore as you don't deserve any further attention.
To the OP, KJB, sorry your thread got hijacked by his foolish remarks, most of here try to give helpful suggestions and stay on subject.
I know there were great assist posts already, but I have come across a few stations who ran out of towels at the pumps do had to use one of my gloves to cover fill hole. If she gets fuel splash, just need to throw in laundry.
Also, don't know if it's different w/tri's as they stand horizontal, but our 2-wheel rides angle so you can get the fill nozzle further into tank. This might help prevent splash-back a bit better than with OP's tri-glide...??
I always carry a fueling rag in one of the lower faring cubby holes. Put the fuel nozzle as far down the left side of tank as possible. Hold fuel lever open full speed until it clicks off, keeping rag around nozzle during fast fill. Then pull nozzle out to bottom of fuelcap opening and slow fill from there.
Most of the time, I stick the nozzle as far into the tank as I can, when it clicks I remove it and go as slow as I can, usually works fine. On occasion I run into one of those pumps that goes fast and that's it...I sometimes get splash back...just wipe it off as best as I can...I carry a can of spray polish and will take care of spills with that....
It happens....
It happens....
