ThunderMax & the Tri Glide?
GPM
Instead of exchanging the ECM why not look at the TTS. You can easily synchronize your VE tables with the VTune software, no dyno needed and it is half the price of the TMax. You will not loose your Anti-Knock protection or have to change your 02 sensors and cables out either.
Anyone familiar with ThunderMax and their maps for the TG? I have installed one on my 2011 Street Glide Trike, after installing Vance & Hines Dress Duals with V&H Trike Slip-ons, and a Arlan Ness Big Sucker I. Zippers recommended the following the 243 map for H-D Trikes with the following adj:
1. Adjust TAC Home Position to: 100 steps
2. Adjust Cranking Fuel to: 11msec
3. Adjust Initial Fuel Pulse to: 151%
2011-2013 Trike Gearing Required Basic Settings:
1. Speedo Cal to: 50750
2. Final Drive Ratio to: 78
3. Gear 6 min TPS to: 40
The 103 ran really rough and started hard. Fuel mileage was down to 28mpg and ran hot.
ThunderMax recommended the 279 map for H-D Trikes with no adjustments. Same issues as before.
Decided to use H-DTouring map 185 for my trike, runs smooth, easy starting, 35-38 mpg cruising and not near as hot. This is what Zippers told me:
" Map 185 has a lot more timing in it, but you should be fine so long as you're not experiencing detonation. As far as I know, gearing and timing changes are the only significant difference between the trike maps and the non-trike maps. I'd still recommend an AutoMap after a few tanks. I'd also recommend verifying your speedo is calibrated correctly (next time you ride with someone, just compare your trip mileage with theirs after a ride). Let me know if you have problems. You're also free to submit a data collection at any time to have us review the data."
Any ThunderMax/Trike users provide me their maps and adjustments that they have found works?
I have a 2012 TriGlide with V&H dresser dual headers, stock slip-ons, stock air cleaner, and Thundermax. I also started with base map 243 but still had knock/ping issues, also rear cylinder (left side exhaust) sounded flat and had marginal power. Checked the 243 base map and found the rear cyl timing was cut back 2 degrees. Went to the 185 base map and bike runs much better but I can still induce knock if hard throttle applied at lower (2.5 - 3K) RPM ranges in higher gears. Hoping I can get rid of that with some more tuning.
I'm a huge fan of the Thundermax ECM.
I put a Thundermax on my Night Train after I installed a Procharger. Initially, I loaded the Map that came with the Procharger and I was not happy with the results. The bike was a beast at WOT but it cruised horrible at part throttle. I looked at the map and realized that the cam specs for the Map that I was provided by Procharger were way different than what I'm running. I chose a new map that had cam specs similar to my cam, added a little extra fuel at the WOT settings and let the auto tune do its thing.
Its amazing how fast the ECM adjust fuel curves.
FYI, The ECM auto tunes AFRs but not timing. Thats why its so important to pick a map that's compatible with your cam and displacement.
Ill leave a couple tidbits here.
ThunderMax is and always has been made by ThunderHeart (not Zippers) in White House, Tenn.
Zippers was their distriubter (still does) for many years and did trouble shooting for them also. They still distribute but trouble shooting is done in house at ThunderHeart now.
The complete TMax, from raw componets, machining, assembly, to final inspection along with R&D is all done at their facility in WhiteHouse.
I have 5 TMaxs on different bikes and all run flawlessly. You just have to work with the unit to get familiar with it.
For the last couple months I have been helping a friend with his PowerVision. Both units, the PV Pro Autotune and Tmax, are quite similuar.
The seperate screen on the PV is a nice touch.
ThunderMax update for Trikes
Ok, y'all. I pulled the Maxi fuse so I could change out my inner fairing. After alot of research, I decided to load the H-D Trike #279 base map with the following mods:
Accel Fuel: 10ms
Idle RPM: 928
Cranking Fuel: 8.5ms
Comp Release Delay: was N/A for this mod
All else was in accordance with the #279 Base Map. Did a test ride today, and it seems to do very well. No rough starting or front/rear cylinder deviations. AFR's appear to be near equal. Gotta give it a chance to Auto-Tune. Then Auto-Map. Will keep ya up-to-date.
Accel Fuel: 10ms
Idle RPM: 928
Ok, icebite1, I'm up for any suggestions that you may have. I'm new at this and I don't wanna mess up the engine. Can you help me? Thanks in advance.
