PM (Performance Machine) TG Brakes Installed
#41
Some day I would like to replace my rear calipers (only) with 4 piston type that I believe only PM makes at this time. I'm sure they wouldn't sell the calipers by themselves.
#42
When I mentioned temperature I was mentioning the master cylinder being blasted with high heat from the front exhaust pipe. I'll bet that brake fluid is making its way real close to 400+ degrees.
#43
With a lot of help from different forums I try to do most of my own maintence. That said I had trouble orginally with stock brakes dealer was never able to get them bleed right. I bought some speed bleeders and 1liter of super blue racing dot 4 brake fluid and 1 liter of typ 200 amber dot 4 fluid. I alternate between the 2 when you have blue in I go to amber that way I can see when I have all the old fluid out. The boiling point on these fluids is 536 degrees and 388 degrees wet. I know have great rear brakes, 2009 Tri-Glide hope this might help.
#44
#46
Yes I was, except I was running the stock master cylinder, I never ran the PM one due to the problems others were having with it. When I sold the brake system it had a brand new master cylinder PM sent me and said it addressed all the issues, looks like they lie.
Slick
05-28-2008 09:55 AM
