Exhaust Wrapping
Exhaust Wrapping
I've asked on a couple of different threads how to do this without a reply. I bought the Fuelmoto stainless header and exhausts. Got the header wrap, stainless ties and high temp paint. Exactly what do I need to wrap and how far down. It does not look like there is much room to get between the two exhaust pipes, header collector and bracket. The top O2 sensor bungs will not be used as mine are on the bottom.
I can also have these headers ceramic coated locally at a reasonable price, any comments about that? Any assistance would be appreciated.
buddy I bought 25ft of titanium rap from DEI am going to rap my down tubes and collector as far as I canto the add on pipe. I bought silver spray sealer to seal rap with wire connectors at start to finish. rap down tubes seperate to collector and then over collector around O2 sensors to end of collector. I am still trying to get you a diagram of my shifter.
Wrapping
Why? rider comfort only benefit worth mentioning!
Wrap everything from the end of the headpipe to the cylinder heads! If your'e gonna do it, do it all! You can wrap in between the 02 sensors.
Just one of the things we do for hot Tri's, if you don't have a heat problem no need to waste your time or money. You ain't gonna hurt those stainless pipes and it will keep a little heat off your thighs if it is a little uncomfortable in the summer!
HP Added
I also thought there was a horspower gain involved? Seems I read this somewhere: Wrapping also increases the thermal retention within pipes and subsequently expedites exhaust flow at a higher velocity. This characteristic increases horsepower. Or maybe the gain on the trike would be insignificant?
When you study the advantages of ceramic you get a little HP gain, the hotter the exhaust inside the header, it scavenges better. The good ones are coated inside and out. The most HP gained in automotive header wrapping is derived by reducing the underhood temps thereby letting the engine get a colder air charge. The cold air kits, ram air and all that are because a cold air charge has more oxygen and that gives you better combustion.
I feel the HP gains from wrapping an external header on a bike/trike would be minimal and negligable. I am sure there would be some small amount of efficiency gained but with a two cylinder engine I doubt it would show up on a dino run.
However wrapping is effective for reducing radiated heat for the purpose of under hood temps or rider comfort. Might not be able to measure much HP gains but you can sure measure the rider comfort on a Tri in August when sitting in traffic.
IMO, ceramic coating stainless steel pipes is an unnecessary waste of $.
Jim
Jim
