Battery Tender
Battery Tender
I have purchased a number of new Harley's throughought the years and have always added a Battery Tender pigtail to the battery terminals. So, I bought one and went to connect the pigtail to my new 2011 TG and discovered there is already one there. Is something Harley is doing now, or perhaps the dealer adds them. I remember when I bought the Harley brand battery tender, the pigtail which connected directly to the battery terminals did not come with the tender. Only the one with the alligator type clips was packaged with the tender.
From my understanding, the factory does not install the pigtail. Some dealers do this to keep the bikes on the showroom floor fully charged. My dealer usually has several bikes on Tenders whenever I go in. I figured it's too keep them ready to ride and to sell. Harder to sell a bike with a dead battery plus it's hard on the battery to let it discharge and then charge it back. It's much better to just keep them charged with a Tender.
Mine came installed and tucked behind wiring between exhaust and crankcase. After melting the plug twice (careless placement while charging), I finally got wise and moved it up behind heat deflector. Since reverse motor puts such a drain on the battery (if I use it) it's a must to use the tender after a long ride and back home.
Thanks for your replies. That's kind of what I figured. Yes, I also keep mine on the tender when it is in the garage. They secured the end of mine on the left side behind the heat shield. I really don't like the location and I will probably relocate it when I remove the seat to install the drivers back-rest, after I purchase one.
