Tri Glide Rear Tires
I can agree with Bulkhed because I was riding my 2010 with him, I ordered my rear tires through Diamond Back Classic Tires http://www.dbtires.com/. I ordered mine mainly because I wanted to have 3/8" white walls to match the front tire. Might be worth calling or sending an e mail and see if they have what you want.
"I was hoping to see someone on here have BFG AT/KO tires installed on the rear for better snow traction..."
Yea but you have to have a balance. Running the AT/KO tires on the back just simply do not work at all with the stock front tire. I believe the recommended replacement for the front tire is a ski.
Which Tires are best?
My guess the stock tires are not the sport or premium model but I've had no problems with my 2012 Tri-Glide in rain or shine. I have studded snowtires for winter (see pic with GF). But I did encounter hydro-planing on my 2003 Motor Trike. I found that Mickey Thompson tires are absolutely greatt but expensive. I also found that towing a trailer will eliminate hydro-planing.
