Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Voltage regulator recall
Old 08-02-2012, 08:46 PM
dwill3332's Avatar
dwill3332
dwill3332 is offline
Default Voltage regulator recall
I received my letter from HD informing me that HD "has recently implemented process improvements at the supplier level to the voltage regulator assembly to address durability issues."
The letter goes on to say they were offering a "no cost upgrade service" on affected 2012 motorcycles. In other words, a recall on the voltage regulator.
Did anyone else receive the recall notice?
Old 08-02-2012, 09:11 PM
TheBobs's Avatar
TheBobs
TheBobs is offline
Just got mine on Monday.
Old 08-03-2012, 09:35 AM
Noble Jim's Avatar
Noble Jim
Noble Jim is offline
Default VR Change out
Got mine replaced at my convenience, not the VR's convenience. Git er done.
Old 08-03-2012, 08:58 PM
Diesel-Dawg's Avatar
Diesel-Dawg
Diesel-Dawg is offline
I wonder why not other year models?, such as the 2011?
Old 08-03-2012, 09:50 PM
dwill3332's Avatar
dwill3332
Default Letter said
The letter said it applied to bikes made between October 1, 2011 and March 31, 2012.
Old 08-25-2012, 05:58 PM
philm8's Avatar
philm8
philm8 is offline
Got mine, can anyone explain what problems this will cause?
Old 08-26-2012, 05:57 AM
msocko3's Avatar
msocko3
msocko3 is offline
It will quit charging your battery and then when the battery voltage drops to low you get to push it home or call a flatbed.
Old 08-26-2012, 07:49 AM
Casper's Avatar
Casper
Casper is offline
It's been discussed a lot over in the touring section...basically a bad batch of VR's....my bike was in the build range, but my VR was not from the effected batch.
They remove you VR and check the serial number....and replace it at no charge if needed.
It's like mike stated, going down the road and bam, VR quits charging once battery is completely drained, bike stops....
usmc68
09-12-2017 06:59 PM
3littlepigs
06-02-2008 01:09 AM
heavy.clutch
Ironhead
09-21-2007 07:38 PM
00garage
Flathead
08-25-2007 05:23 PM
gsparesa
11-14-2005 01:29 AM
Quick Reply: Voltage regulator recall
