Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
6500 mile Road Trip
Old 08-18-2012, 10:29 PM
dw2169's Avatar
dw2169
dw2169 is offline
Default 6500 mile Road Trip
I just finished a 6500 mile road trip to Texas by way of North Carolina. It was a great trip but did have a few problems. I was in Minnesota and my TomTom went blank. I pulled into a parking lot, shut the trike down, and figured out my problem with the TomTom. I fired up the trike and it would not go above idle. I shut it of and started it again and still would not go above an idle. Lucky for me, I only had to idle three blocks to my destination. Let the bike sit for a couple hours and it fired back up and everything was normal. Next problem was a couple of days later after filling with gas, two miles down the road, the speedometer quit working which took out the cruise control and mileage meters. I rode about twenty miles and shut the bike down, upon restarting everything worked again. Has anyone else experienced these problems?
Old 08-19-2012, 07:42 PM
joe momma's Avatar
joe momma
joe momma is offline
...electrics always drive me nuts....
...i have not had this problem.......
...but if i did....here is what i would do..
....while in your garage...disconnect and clean your battery terminals
........use a battery wire brush on the posts and the connecting wire.
...then reassemble it....
...go in your house have a beer or so...
...and the next day...start up...and see what happens..
..this may sound a little strange......
.....try it and see
.good luck
Old 08-20-2012, 03:31 AM
msocko3's Avatar
msocko3
msocko3 is offline
When my dad and I went to the New England states I had a strange happening. After a gas stop I noticed the XM radio from my Zumo 550 had quit, 1st thought I might need to cycle the power on the GPS because its little brain gets scrambled at times. Once I hit the freeway I went to engage the cruise so I could work on the GPS and found I had no cruise. I then started looking around and found I had lost power to my Aux, my stereo, my cruise control, plus the turn signals and the brake lights.
I pulled off into a rest area and shut it down to check fuses, for grins I pulled the 40 amp Maxi fuse and put it back. I turned on the ignition and everything was back. Never did figure out what the cause was, never will because I don't own it anymore.
satman
11-07-2013 04:03 PM
msocko3
07-11-2012 08:06 PM
EVOrider
EVO
05-27-2010 12:18 PM
wiredwilly
10-22-2009 11:58 AM
Ridewva
06-16-2009 09:21 AM
Quick Reply: 6500 mile Road Trip
