Clutch problem?
Clutch problem?
Hi, I am a relatively new rider and a new owner of a used 2011 Tri Glide. I am not able to do much mechanical work and have limited mechanical knowledge, especially as related to bikes. Therefore I know that I will pay. But some information will help the paying pill go down.
So here is my inquiry. Recently on an out of town trip I started hearing and feeling a chatter while taking off in 1st gear. Stopped at a Dealer and was told the problem was probably the automation tensioner.
Arrived home and went to a local dealer....Stated that previous opinion was bull it was the compensator and could not be adjusted but must be replaced as it would damage all parts of the drive train. And even tho I have HD Extended warranty it was not covered. I spoke to a person with huge experience with HD he felt it was a waste of money to replace the compensator with one from HD as it would not stop the problem. That there is an upgrade that is much better.
I am not asking what the compensator does or how it works just, info on the best way to handling the problem..
Ride Safe.....Ride Smart
Tom
Tom
Tom
Tom
Tom
Tom
Yes, some of us are having compensator issues and it could be that. Did anyone think it could be as simple as a clutch adjustment, weak spring or that he may have one of the bad clutch assemblies?
My '12 clutch chattered from a dead stop in first gear. It was the clutch adjustment. Riding in hot weather it came back. Installed the CW and a SE Spring which seemed to totally stop the chatter.
Does the compensator chatter? Does it make a chatter that you can feel? When you take off in first then suddenly get off the throttle and back on you can hear a slap but that is the primary chain adjuster. When a compensator goes bad you can hear a pop when you turn the motor off.
Don't claim to know it all but instead of concentrating on extended warranty maybe we should be concentrating on discussing what the real issue is?
Just say'n
Hey guys.... was the real problem missed here?
Just say'n
Just say'n
When a compensator goes bad you can hear a pop when you turn the motor off. .Don't claim to know it all but instead of concentrating on extended warranty .maybe we should be concentrating on discussing what the real issue is?
Just say'n
Just say'n
