Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Reverse Motor Circuit Breaker
Old 01-29-2013, 04:46 PM
Scorpio49's Avatar
Scorpio49
Scorpio49 is offline
Default Reverse Motor Circuit Breaker
2013 TrGlide. Reverse quit while backing up on small incline. I believe I popped the circuit breaker. Manual says the circuit breaker is located in the electrical caddy. Where is that located? The little picture diagram they show is no help. How do I access it?
Thanks for your help
Old 01-29-2013, 05:14 PM
icebite1's Avatar
icebite1
icebite1 is offline
The reset is behind the right side cover. You cant miss it after you pull the cover off.
It is a red lever, just push in till it locks in.
This is a common occurance with the HD electric reverse.
Old 01-29-2013, 07:47 PM
PIGGI's Avatar
PIGGI
PIGGI is offline
HD recommends you rev the engine up some to overcome the load on the battery the reverse motor creates.
Old 01-29-2013, 08:27 PM
icebite1's Avatar
icebite1
icebite1 is offline
I heard that and tried it .
Kept high rpms and tried to back up a short incline and it popped the breaker, reset it and tried again at normal idle with the same results at the same distance. you cant even get a running start cause it only goes slooooow.
Old 01-29-2013, 08:47 PM
Delta's Avatar
Delta
Delta is offline
I think the manual says that if you engage the brakes while backing up then the breaker will trip. I concentrate on taking my thumb off the button before braking. Do you think this may be the cause of your problems?
Old 01-30-2013, 06:39 AM
bronxbill's Avatar
bronxbill
bronxbill is offline
Just a quick heads up, on my 2011 Triglide the circuit breaker lever is grey. Icebite is correct, its hard to miss once you take the side cover off.
Old 01-30-2013, 07:15 AM
icebite1's Avatar
icebite1
icebite1 is offline
The gray lever is only for old guys- just kidding.
Didnt know they were any color but red, is gray on '11 up models ?
Old 01-30-2013, 02:39 PM
msocko3's Avatar
msocko3
msocko3 is offline
FWIW I think the reverse system is inconsistent, some folks have the breaker trip on slight inclines while others don't. I've backed up the 2010 I had 2 up with a loaded Aluma MCT trailer without tripping the breaker. I think the manufacturer Harley uses for the breaker must have poor QC, you just don't know how much load it will take before tripping. The 3 years I had my 10 I never tripped the breaker. When I 1st picked it up the salesman hit reverse with the parking break on and the breaker didn't trip.
Old 01-30-2013, 03:55 PM
bikerbum's Avatar
bikerbum
bikerbum is offline
Ditto Ms03. My 09 has never tripped, and I'm a BIG BOY.
Old 01-30-2013, 05:03 PM
oldmsocko's Avatar
oldmsocko
oldmsocko is offline
I have also never tripped mine. Now that I have opened my big mouth it will trip.
Quick Reply: Reverse Motor Circuit Breaker
