TG Adaptor Plate for HD Front Fork Baffle
Fork Baffle
I took two one inch by 2 inch 1/4 inch bar stock aluminum with two holes in each one and mounted the regular Harley Fork Baffle on mine. Was easy to make and works great. It looks like it was make to fit that way. Just drill a hole in each of the bar stock and fasten them to the bike in the factory holes. Hold the Harley Baffle up and mark the holes that are in the baffle on to the bar stock. Drill the holes out and fasten the baffle. Pretty simple and inexpensive to make.
According to Harley online the Front Fork Air Baffle fits up to 2013 Ultra's. They do not list the 2014 Ultra. 2014 they change the diameter of the Front Forks on the Tri Glide and they probably had to change the design of the triple trees. The current Front Fork Air Baffle probably doesn't line up with the holes of the 2014 lower triple tree, if it even has them.
Only real way to tell is to compare the lower triple tree with steering damper on the 2014 vs any previous year Tri Glide. It could be you just have to alter the hole position of the Adaptor Plate to the holes that may be in the lower triple tree of the 2014 MY.
There are only 5 cuts that you have to make and 4 holes to drill. If you have a Jig Saw with a metal cutting blade the cuts are quick. But, you can make these cuts with a Hand Held Hack Saw. The first cut is to get a piece of Aluminum Bar Stock 12 1/2" long out of your 36" piece that you bought at Lowes or Home Depot. The other 4 cuts are to make the left and right notches on the Plate.
To lay out the holes all I used was the Baffle itself. I found the center line of the Adaptor and marked it top to bottom. I then found the center of the Baffle on it top edge and marked it with a Sharpie. For the top holes that go into the lower triple tree I place the Baffle so its top edge was even with the top edge of the Plate and then outlined the holes from the Baffle. For the bottom holes in the Adaptor I turned the Baffle around and line up the top edge of the Baffle with the bottom edge of the Plate and again outlined the holes from the Baffle. Once I had the holes drawn I then took a center punch and put a healthy punch in the center of each hole to guide me drill. I used a 1/8" drill to make a pilot hole in all four holes. I then switched to a 5/16 drill and the first thing I did was flip the plate over and drilled a slight bevel in each hole. Doing this gives you a clean exit hole once you drill from the other side through the plate.
I bought mine from Dennis Swan along with his fork wind deflectors. http://www.tglidestuff.com/
Dennis
