Installing Brakes
Installing Brakes
Hello All.. I need to install new brakes so I have to buy 4 sets 2 for front 2 for rear I called J&P got part #244-797 which will fit front or rear. My question is My rear brakes have squealed since day one and was wondering if there is a pad out there which will stop that . And I have changed brakes on all my cars
(DISC) is doing a bike any different ?
brakes
I have not replaced the brakes on my TriGlide, the front will be like any other bike and I'm sure the rears pretty simple when you look at them as far as the squealing goes I would rough up the rotors with emery cloth to get rid of the glaze. Make sure that your parking brake is not adjusted to tight when released this will cause the pads to drag ad polish them causing a squeal.
I know its been said before, but just in case you have not heard, a lot of us have removed the rear parking brake ***'y completely and opted to use a small velcro strap around the front brake lever/throttle. I do this when on a slop when I do not trust 1st gear only. Personal choice of course.
