Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Ongoing '14 Tri-Glide build-out, lots of pics, & thoughts on the differences
  #91
Old 09-04-2014, 12:22 PM
DK Custom's Avatar
DK Custom
DK Custom is online now
Platinum Sponsor
Received 3,930 Likes on 2,288 Posts
Originally Posted by coronetracer65
I purchased them from you when I bought the lift kit ! LOL. Thanks , Ebert
Give the shop a call or email...we rarely see a defective one, but it can happen.
We'll take care of it for you.
__________________
Kevin
DKCustomProducts.com
Call/Text: 662-252-8828
  #92
Old 09-04-2014, 07:09 PM
coronetracer65's Avatar
coronetracer65
coronetracer65 is offline
Thanks Kevin email sent I hope !
  #93
Old 09-18-2014, 05:42 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
One thing I thought I noticed on the 14 that was different than the 11...when hitting curves/sweepers aggressively the 11 would skip the front tire thru the curve.
The 14 did not do that, but I thought it might be because I had been riding it a bit more conservatively.
But recently I've been hitting the curves just as aggressively (or more so) on 14 as the 11, and it is not doing the skipping.
So that is another improvement...either due to the heavier forks, redesigned trees, improved internals, or probably all three.
I know that the skipping on the 11 was a big contributor to front tire wear. It will be interesting to see how much longer the front tire lasts on the 14.
  #94
Old 09-18-2014, 11:06 PM
TwinCooled's Avatar
TwinCooled
TwinCooled is offline
I have been running 36 psi in my front tire and at my 5000 mile service (yesterday at 5300 mi.) the service manager showed me uneven wear on my front tire. He recommended 40 psi. I'm going to take his advice and see what the difference is. I also am pretty aggressive when given the opportunity. I do think that the improvements made to the front end on the 14 and up models probably account for the change and the need to run a higher front tire psi. They also changed my rear psi from 22 to 24psi.
I made them put them back to 22.
  #95
Old 09-22-2014, 09:09 AM
Ribitt's Avatar
Ribitt
Ribitt is offline
I have been running 40 psi on the front tire,22 psi in rear since day one, which was in april for the 14 and with just over 6k the front tire still looks new. do not understand the short life of a front tire people are having.
ps. kevin love the comfort lift.
Ribitt
  #96
Old 09-22-2014, 09:50 AM
COFLHTK's Avatar
COFLHTK
COFLHTK is offline
I ride mine pretty aggressively through corners as well. On a recent trip one of my friends on a Ducati wasnt even able to keep up with me. But she did note that going through one of the corners it looked to her that I got the inside rear tire off the ground just barely. Never felt unstable to me though.
  #97
Old 09-22-2014, 05:11 PM
mwessel's Avatar
mwessel
mwessel is offline
Grabbed rubber a couple times on my inside doing the Dragon. You know you did because wifey will smack ya in the head.
  #98
Old 09-22-2014, 11:47 PM
sloufoot's Avatar
sloufoot
sloufoot is offline
Moderator
Received 4,081 Likes on 3,483 Posts
Isn't it odd how they can do that so quick after they let go of the grab handles HA !
  #99
Old 09-23-2014, 02:06 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Ribitt
Cool, happy to hear you're enjoying it!
Re- front tire. It's all in how you ride and where you ride.
Summer before last I spent a long weekend in the Ozarks. Put a little less than 1000 miles on a new front tire. Almost every mile was pushing hard through tight turns, scrubbing rubber off the center of the front tire. In that short time I wore over 50% of the front tire off in less than 1,000 miles.
But I have also gotten over 15,000 miles out of a front tire...just normal riding, interstate and country roads, no pushing it hard thru the twistys.
  #100
Old 09-23-2014, 02:08 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
This vid has 5 short (less than 1 minute) sound clips of different bikes exhaust. The last one on it is my 14 TG.
Really happy with the sound, it has a low rumble, with a bit of bite, & a nice lope.
Quick Reply: Ongoing '14 Tri-Glide build-out, lots of pics, & thoughts on the differences
