Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Taller Bars Tri Glide
Old 07-05-2014, 06:25 AM
hapbob's Avatar
hapbob
hapbob is offline
Default Taller Bars Tri Glide
I don't see much in this section about changing Bars on triglide...I would love my bars 2" taller and 2" closer and have looked into it on the touring pages. Thought I would throw it out here in Tri Glide since that's what I have. Anyone change bars out and to what? I would like to try the Yaffe 10" classic bagger bar but when I go to JP cycles to order it says won't fit triglide? But they seem to work on street glide and unlimited models? so I wonder if they really do work for the TriGlide. Any advice is good
Thanks
Hap
Old 07-05-2014, 09:03 AM
Casper's Avatar
Casper
Casper is offline
I want to change too, been looking at the La Chopper, Twin Peaks, 10"
I've heard no changes needed, but can't say for sure...my biggest concern is the clutch cable...some body please chime in..
Old 07-05-2014, 11:51 AM
azbob09's Avatar
azbob09
azbob09 is offline
I just changed to the Hd reduced reach bars which are suppose to be the same as what they use to call the 2" pull backs that we had on our 2010 & 2012. I like them just as well as as I did the 2" pull backs.
Old 07-05-2014, 12:48 PM
Moneywoes's Avatar
Moneywoes
Moneywoes is offline
Thanks
Hap
I wondering if theres not enough room for the reverse switch on the Yaffe's?
Old 07-05-2014, 06:45 PM
hapbob's Avatar
hapbob
hapbob is offline
Default Could be
Reverse switch....that is an idea. I will look into that a bit more.
I have the reduce reach bars coming. Will try EM and see if they do enough for me.
Hap
Old 07-08-2014, 05:57 AM
tbob's Avatar
tbob
tbob is offline
HD ape hanger 57474-11, 69100278-69100279 - Wire Harness. used all stock cables.
three hours and a few beers.
Old 07-08-2014, 06:44 PM
Skeet7373's Avatar
Skeet7373
Skeet7373 is offline
Old 07-10-2014, 03:53 AM
DK Custom's Avatar
DK Custom
DK Custom is online now
Platinum Sponsor
Received 3,930 Likes on 2,288 Posts
Thanks
Hap
I just went thru this whole process....it is different for the 2014's than previous years.
They make clutch line the length you'll need for 2" taller and 2" back. They also make the brake line for that configuration. If you go much more you'll need to get a custom line made for the brake side...as of last week no one was making them.
The will need to install a new twist grip for the throttle.
There is no difference in the bars for the Tri-Glide and the other batwing 2 wheel bikes.
There IS a difference between the bars from 09-13 and the '14's.
Check out post #56 in the following thread...that is the latest update on my handlebars...I will be posting pics soon of it finished up.
https://www.hdforums.com/forum/tri-g...fferences.html
__________________
Kevin
DKCustomProducts.com
Call/Text: 662-252-8828
Old 07-12-2014, 04:33 PM
hapbob's Avatar
hapbob
hapbob is offline
Default Diffferance
So Kevin what is diffferance between 09-13 and 2014. Looking at bars in catalogs they don't list the 2014 as fitting for yaffe 10. But in touring section ,a
Many have put them on streetglide 2014 so wonder why not fit a 2014 trike?
Any input is appreciated. I really want to try EM of there is a possibility.
Hap
Old 07-12-2014, 04:36 PM
hapbob's Avatar
hapbob
hapbob is offline
Default Diff
Or anyone else with info on these bars or others on the 2014 trike.
Hap
Quick Reply: Taller Bars Tri Glide
