Fl-vied-10
Fl-vied-10
I am currently running the knight rider fl-vied-10's on my stock 2014 Trike. I have a set of stock headpipes that have been decatted , and getting ready to change them out along with Rush big louie 4" slipons with a 2" baffle . Will the vied's handle this alright ? Can't afford a tuner right now !
Received 3,931 Likes
We sell a LOT of XiED products...and I recommend them as a budget solution to the too lean factory tune on a regular basis for every HD except the TG.
Not that they do not benefit the TG, they do. However, I am of the belief that the TG with all its' weight and wind resistance should have more help than the XiED product can give.
That being said, if you are satisfied with them now, there is no reason you won't be after adding the Rush Slip-Ons.
Instructions are general guidelines, everyone's experience is different. Start out at the setting you are on...then try going a bit in each direction. You will be able to tell which setting is giving you the smoothest, strongest acceleration.
