Help hooking up lights
The connector you are looking for is located under the seat between back of the tank bracket and the battery (I'm assuming you have a TG). It's buried beneath a couple of other wire harnesses. I haven't tried but you might be able to get the connector that plugs onto it at a HD parts desk. I usually just use a remote switch added to the inner fairing somewhere and connect all the wiring directly to the battery. Just make sure you use an inline fuse holder if the kit doesn't come with one.
hooking up lights
Watch out for the LEDs that require a diode for them to operate properly.
