CB watts out put
Yes, I know what the legal limit is, but the Tri Glide has a lousy cb radio with very high SWR readings from the stock antennas which may have damaged the finals in the radio, so has anyone check the output with a meter?? Checked mine with stock antennas and was only 1 to 1 1/2 watt with modulation, very low but the dealer says it works cause it can transmit to another bike 20 feet away.
NamVet, you already know about Sierra Electronics. I know they can check and set the SWR's on your CB not sure about the power output.
Since they aren't too far away from you, and it would be a nice day ride, you may want to call them and check.
I remember back in the day, they used to sell and service CB's for all the big name trucking company drivers around this area, as well as set them up in their bikes.
The Power should show 3.5 to 4.0 watts on a dead carrier. (No Modulation) You don't have a sideband.
The big problem with a motorcycle doesn't have a ground plane to work off of. Also the antenna is at an angle not right angles with anything else. I checked my SWR on my Trike & it was over 3! But I can talk about 1.5 miles. I'm still working trying to get the SWR down. It should be below 1.5:1.......
Harley doesn't want anything to do with diagnostic of the CB. Like others have said, If it will transmit 20 feet that is all they want. And you are correct about the high SWR taking out the finals ! It Will !
"sounds like crap" is not a measurement, it is an opinion, and has absolutely no relationship to RF power output.
