Throttle position sensor wiring failure prone.
Just a warning for something you may want to check out. Our 2012 Ultra Classic TriGlide was enroute to Morro Bay, when I lost throttle in cow country. I could start it up, but got absolutely no throttle.
In another thread, I detailed the entire experience. But, the short story was that the pins in the connector at the throttle position sensor (behind the AC) were corroded and fried. The dealer that did the work, claimed this was common, and that Harley has tried several time to fix it. As a testimony to the frequency of occurrence, the dealer had 12 repair kits in stock.
So, from now on, as part of my oil change frequency check over, I am going to unplug this connector and examine the pins and wires. You may want to do the same as a 1 minute preventative measure could save a lot of aggravation.
mctraveler (12-07-2017)
Had the same thing hapen to me in 2012 during Run For the Wall. I lost throttle action about 100 miles west of Junction City Kansas. After shutting down and restarting a few times it started working again. The tech at the HD dealership in Junction City found the problem, cleaned out the connector and reconnected it using some dielectric grease. He said that it was a common problem for moisture to get in the connector over time and for me to check it at every oil change.
Received 3,958 Likes
I've seen this failure more than a few times.
Knock on wood, in almost 100k miles over three different TBW bikes I've never experienced it.
In the several people I've spoken with that have experienced it, they have been aggressive in washing their bikes, with higher water pressure.
Those of you that have experienced it...do you wash your TG's with high pressure, or let a steady stream of water hit the connector? Curious to know if that is the correlation, or if it is just hit and miss on some corroding and other not.
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
talkingrock (12-07-2017)
Also, I had an issue with oil drool from the AC. I don't recall seeing any on that connector, but it wouldn't take much to mess it up.
I'll be going after all the connectors I can find with dielectric goop.
Not my bike, but here's a 14
Here is a pre-14-
Fearless (old nickname) (09-15-2017)
Thanks for posting the pictures Kevin. Yeah, in retrospect the design on my Trike sux! Water is bound to get into the pins, and down the jacket.
I ordered some larger diameter shrink tubing from Amazon so I'm going to seal the sucker up, and coat the pins well with dielectric grease. I haven't unplugged the connector yet to see if the repair the dealer did included dielectric grease.
I'll probably do the work next week. In the interim, no washing until I do the upgrade.
I'll post picture updates. As is, mine looks just like the second picture Kevin posted.
