Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
TriGlide Rear Wheel Car Equivalent
Old 08-20-2014, 12:57 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,360 Likes on 11,173 Posts
Default TriGlide Rear Wheel Car Equivalent
I know this question has been asked before, but I can't find where anyone answered it. Has anyone identified an automobile wheel equivalent to the 15" TriGlide rear wheels?
Seems if there is an equivalent, then we would not be limited to the few options for replacements from Harley.
Old 08-20-2014, 03:58 PM
COFLHTK's Avatar
COFLHTK
COFLHTK is offline
Looks to me like there are lots of options.
http://www.tirerack.com/tires/TireSe...65&diameter=15
Edit: Nevermind, you said wheel. I'll do some digging around tomorrow if I have time.
Old 08-20-2014, 04:06 PM
don56's Avatar
don56
don56 is offline
Stage III
I bought a set of rims off of a 2010 TG for a trike I'm starting to build. The bolt pattern is 4x4.25. This is a list of cars that use the same pattern. 78-86 Ford Fairmont, 81-83 Granada/Maverick, 83-85 LTD, 65-73 Mustang, 71-80 Pinto, 80-88 T-Bird, 71-86 Capri-Capri ll, The Plymouth Cricket also had a 4.25 pattern. The Toyota Van 89-90 uses the 4.25. There may be some more Ford models using the 4.25 pattern but not any other brands.
Old 08-20-2014, 07:11 PM
TriGeezer's Avatar
TriGeezer
Cool! I'll look into the ones you suggested! Thanks for the info!!
Old 08-20-2014, 10:38 PM
sloufoot's Avatar
sloufoot
sloufoot is offline
Moderator
Received 4,083 Likes on 3,485 Posts
If it was the bolt pattern that was the only thing to look for things would be simple ! You also have to look for the correct offset & width. Remember things have to fit under the fender without touching the body & without changing the axle position....... Just sayin...
Old 08-20-2014, 11:18 PM
TwinCooled's Avatar
TwinCooled
TwinCooled is offline
Great advice.
Old 08-21-2014, 11:54 PM
sloufoot's Avatar
sloufoot
sloufoot is offline
Moderator
With that being said,,,, About a year ago I found an adapter to change from a 4 bolt pattern to a 5 bolt. They would have to be at least 1" thick to be able to cover the lug nuts or nuts. So you would have to go with more offset in the wheel to put the tire in the correct place. But they were a bit expensive also.
I can't find the site right now, but you might look for them on web searches.
Old 08-22-2014, 12:26 AM
Casper's Avatar
Casper
Casper is offline
One of the things I like about the TG wheels is that the front and rear match. Changing the rear wheels only wouldn't look as clean to me. But to each their own.
Old 08-22-2014, 08:34 AM
sprinkman's Avatar
sprinkman
sprinkman is offline
I would be more interested in the rotors if there were a auto replacement.
Elwaupo
Wheels/Tires
07-22-2019 05:47 AM
Yo Nadz
03-30-2015 11:52 PM
Bearfan
04-05-2013 06:25 PM
joechief
02-02-2011 08:07 PM
Z06_Pilot
09-22-2008 04:12 PM
Quick Reply: TriGlide Rear Wheel Car Equivalent
