V-Rod Models V-Rod Model Parts Only
Rear Brakes of VRSC-A 2006 stuck
Old 02-15-2017, 06:54 PM
ocasioa23's Avatar
ocasioa23
ocasioa23 is offline
Stage II
Default Rear Brakes of VRSC-A 2006 stuck
Does anyone have experience that the Rear Brakes of VRSC-A 2006 get stuck and don't get loose?
Old 02-16-2017, 11:00 AM
Scuba10jdl's Avatar
Scuba10jdl
Scuba10jdl is offline
Wrong section here, you want the VRod section.
However, a stuck brake points to the master cylinder not releasing the pressure. Either plugged up with gunk (dirt, debris, never changed brake fluid) or it needs rebuilt.
Old 02-16-2017, 11:28 AM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
check the brake lever for a swollen bushing. I had that happen on my Dyna. Brake would just get stuck randomly. I bled the brakes, double checked everything and it still kept happening. Then i check the pedal... boom... swollen bushing. I pulled it and honed the plastic bushing. Problem solved.
https://www.hdforums.com/forum/showp...&postcount=216
Not saying this is your issue but, disconnect the brake linkage and check the movement of the lever/pedal on the mount.
If not, methodically clean/ service you rear system, link already mentioned. Sounds harder than it actuall is.
hitthecoast
02-22-2020 01:10 PM
Marc Lastrella
10-29-2017 06:27 AM
blueangel73
07-16-2016 09:59 AM
Matt K
11-20-2013 06:26 AM
FatBobber08
07-24-2009 10:13 AM
Quick Reply: Rear Brakes of VRSC-A 2006 stuck
