Correct map change?
Correct map change?
Bought the FP3 Tuner. Great product by the way. Just want to double check with you on a map. I used your previous recommendation for my set up which is stock A/C breather, HD Screaming Eagle Street Cannon slip ons. You said go with V & H Hi Output slip ons for my map. I did that & it worked great. Today I installed a decatted head pipe & kept everything else as is. I flashed map V & H Hi Output slip ons with Dresser Duels this time. Due to weather, I was only able to take a 10 minute ride, but it seemed fine. Am I good or would you recommend something different? Thanks,
Keith
Keith
