helloo, all ,,just wondering the best way to allign rear wheel , just ordered new tires, and would like to make sure the rear is straight,,it an 2012 electra glide ultra limited,,,thanks
As stated above, the cams on the axle will take care of the alignment. They will also function in making sure you get your belt tension correct. Don't be alarmed if they are not where you marked them when your belt is at the proper tension...
